PST to NSF Conversion Tool
One can easily transfer Outlook PST data to Lotus Notes NSF file with eSoftTools PST to NSF Converter software. This tool has the ability to fetch all the information from Outlook PST and provide a preview of all its inner data before conversion. This makes the selection of elements easier for the user for selective exportation. Any element of the mailbox can be chosen for migration which may include emails, contacts, calendars, etc. Outlook installation is not required to perform exportation. A free demo version is also offered to all users which supports making PST to NSF Conversion with selective 15 emails without any charges.
Get More Info:- PST to NSF Conversion Tool
You can easily migrate PST file to NSF format. The tool simply converts PST file data of different mail client to NSF file. Using this software you can also check the preview of mailbox data items before migrating the file into any other file like NSF, MSG, EML, PST, and EMLX formats. This application supports all latest version of MS Outlook and Windows. Download the free trial version for migrate PST file to NSF.
Are you looking best PST to NSF Converter Tool? I am recommending the best WholeClear PST to NSF Converter which fastly converts PST folders with internal elements contacts, tasks, calendars, journals, reminders, notes, appointments, and attachments to MS Outlook PST formats. It utilizes less time to perform PST to NSF Conversion. With this software, users save the converted data in the desired location over the local machine.
