Anshu_123
Exporting Rackspace emails to PST format can be accomplished through both manual and automated methods. Below are step-by-step instructions for each approach.
Manual Method Using Microsoft Outlook
Phase 1: Configure Rackspace Account in Outlook- Open the Microsoft Outlook application on your computer.
- Click on File, then select Info followed by Add Account.
- Choose Manual Setup or Additional Server Types and click Next.
- Select either POP3 or IMAP and click Next.
- Enter Details:
- Your Name: Your full name
- Email Address: Your Rackspace email address
- Account Type: Choose either POP3 or IMAP based on your preference.
- Follow the prompts to finish adding your account.
- Click on File, then select Open & Export, and choose Import/Export.
- Choose Export to a File and click Next.
- Select Outlook Data File (.pst) and press Next.
- Choose the email folders you wish to export and click Next.
- Browse to select a location to save the PST file and click Finish.
Automated Method Using Third-Party Software
For users with extensive email data, utilizing specialized software can streamline the process:- Install and open the Cigati IMAP Backup Tool on your system.
- Select the Rackspace email source and enter your login credentials.
- Choose which email folders you want to export.
- Opt for PST from the available saving options.
- Specify where you want to save the resulting PST file.
- Click on the Backup button to begin the export process.
