Reasons behind conversion from EDB to PST
Ethankoles
EDB files related to businesses generally remain big. Moreover, they are inaccessible once they are stored in the local directory. This scenario pushes users to look for a reliable way to convert the EDBs to accessible file format. On the other hand, it is seen that users prefer to convert EDB to PST rather than to other file formats. If you plan to convert EDB to PST, you can use Shoviv EDB to PST Converter tool. The Shoviv tool provides a safe and secure medium for this highly technical task. This tool comes with a simple GUI to make the procedure easy and doable.
Features of Shoviv EDB to PST Converter:
  • This tool converts EDBs of any size and number in a single go without compromising efficiency and speed.
  • Weeom EDB converter tool converts both the public as well as private folders of the EDBs.
  • It has PST split feature to give users an option to split PST as per their desirable size.
  • Folder mapping and email translation features are embedded in this tool.
  • Its filters allow users to perform the selective conversion.
Users can use this tool in the FREE demo version to assess it well before purchasing.
Read more: https://www.shoviv.com/blog/edb-to-pst-conversion/
