onyiersan
If you want to recover data from Samsung Galaxy S6 broken screen or black screen, this post will teach you a easiest way to unlock your screen and get your data from broken screen Galaxy S6, S6 Edge and Galaxy S6 Edge+.
U.Fone Broken Android Data Recovery software is Highly recommended for you to recover deleted or lost data from broken Samsung Galaxy S6/S5/S4/Note 5, ect. You can use this broken Samsung data recovery software to recover text messages, contacts, call history, WhatsApp, pictures, etc. from broken Samsung phone. What's more, the program enables you to directly scan and recover deleted files from Samsung Galaxy S9/S8/S7/S6/Note 9/Note 8/Note 5/A9 internal storage and SD card, after scanning your devices, then you can preview the data in detail one by one, and extract all your phone data to computer with one click, you can selective and flexibly backup and restore Samsung data. It’s suitable for accidental deletion, factory reset, OS update, rooting, virus and other unknown causes. U.Fone Android Data Recovery is better than imagined that allows to recover Samsung Galaxy S6 edge Plus lost/deleted data including contacts, text messages, photos, WhatsApp messages, videos, and call history so on. Not only for restoring data from Samsung Galaxy S6 edge Plus, it also supports to restore data from various Android phones and tablets like Samsung, HTC, LG, Motorola, Sony, Google Nexus, etc.
In additional, you can use this U.Fone Broken Android Data Recovery to fix cracked Samsung Phone (bricked, system-crash, virus-attack, etc.) to normal and extract files from broken/frozen Samsung phone, so that you can use your device again.If your Samsung phone stuck in black screen or it stays in broken screen, system is damaged or non-responsive screen, or you cannot enter password or connot touch the screen, stuck in startup screen, stuck in the download mode. Don't worry, you can use this Fix Android function to it can fix some issue to get the phone back to normal and recover existing data from bricked/broken Android phone.
U.Fone Broken Android Data Recovery currently only support some Samsung devices like Galaxy S6/S5/S4, Galaxy Note 5/4/3, Galaxy Tab.
How to Recover Data from Broken Samsung Galaxy S6
Step 1. Run the U.Fone Android Data Recovery and Connect Your Phone
After launching the recovery program on your computer, choose "Broken Android Data Extraction" in the primary window, and connect your phone to PC via its USB cable.
When your phone is detected by the program, please click the "Start" button on the left to enter the fixing feature of your phone.
Step 2. Choose Samsung Phone Model
Then on the new window, choose the correct "Device Name" and "Device Model" for your phone. Currently this function only works for some of Samsung devices in Galaxy S, Galaxy Note and Galaxy Tab series. Please select "Galaxy S6", the program supports SM-G9200, SM-G920F, SM-G920P, SM-G920T, SM-G925F, SM-G925P, SM-G925T, SM-G928P, SM-G928T.
Begin your start, please enter "confirm" to make sure that you have chosen the right name and model of the device that you need to recover data from.
Step 3. Enter Download Mode on Your Broken S6
Here, the program need your S6 to enter the download mode, you can follow the below three instructions to get your broken S6 enter the Download Mode.
a. Power off the Galaxy S6.
b. Press and hold Volume "-", "Home" and "Power" button on the phone concurrently.
c. Press "Volume +" button to enter download mode.
Step 4. Analyze Your Broken Samsung Galaxy S6
Then make a connect between your broken Galaxy S6 and the computer. Samsung Galaxy Recovery will analyze the phone automatically.
Step 5. Preview and Recover the Data from Broken Samsung S6
After step 4, Samsung Galaxy Recovery will display all the file types by categories. Then you can choose the files you need and simple hit "Recover" to save all the precious data you need with a click.
Video Guide: Recover Data from Broken Samsung Galaxy phone
Recover Photos from Broken Samsung Galaxy S6/S6 Edge
Recover Data from Broken Screen Samsung Galaxy S6 Edge Plus
