I used Eraser to erase a Seagate external hard drive. I deleted a few of the files by specifically picking them and erasing them and deleted some the normal way. I then moved the files I wanted off the drive and performed a 3 pass free space erase. Just for grins I turned plausible deniability on. Not sure I used this right however...I only picked one file (C:\WINDOWS\system\TIMER.DRV). Anyways, I then used Recuva to see what it found. It found some files that it says were not deleted such as $Boot, $LogFile, and $MFT. The only path for these is E:\. Other files that it says were not deleted were $Quota and $Reparse in E:\$Extend\. It also says change.log and MountPointManagerRemoteDatabase were not deleted and these are located in E:\System Volume Information\. Do you think I need to worry about these files?
It also found thousands of randomly named files with no extension. They are also located in the same randomly named folder and are the same size. They were last modified at the same time. Their state is excellent but from what I've read this makes sense and these files are securely deleted and unrecoverable. Is this right? There are also tons of other randomly named files that are listed as in poor condition or unrecoverable.
It also found two desktop.ini files in Recycler. Anything to worry about?
One last question. Since I turned on plausible deniability shouldn't Recuva not even show that these files were erased? Or am I not understanding this process correctly? Sorry for the long post. Just want to make sure I understand what I'm doing. Any help would be appreciated
