Overwriter said:Why do you say you will never use them ? Surly if you have downloaded and installed Eraser you must be at least a little security conscious !!!
I suppose I can get used to the extra items on the Recycle Bin context menu, but I doubt I'll ever use them, so they're just annoying at this point. But as I said, if there's no way to remove them, I suspect that I'll get used to them.
