Yuvraajsingh
The Enstella Exchange EDB to PST Converter is the best reliable software because. It’s really helps you to repair all EDB file data and after that Convert into PST file. This software allows you to export any number of mailboxes. No matter of size of the database or mailbox. You can recover and export even large sized mailboxes. This software effortlessly makes coordination with every MS outlook file version from 97, 2000, 2002(XP), 2003, 2007, 2010 and 2013 (32 and 64 bit).
