The most suitable and smart solution to convert Lotus Notes to Outlook is eSoftools Lotus Notes to Outlook Converter Tool that is one of the most trusted software that is capable to convert your lotus notes along with its mailbox components such as emails, journals, tasks, drafts, calendars, and contacts. By using this tool users can take the benefit of its multiple features and use it without any doubt. The cool utility gives the display the preview of NSF files before the conversion and users can migrate any size of NSF file without any difficulty. It is proficient software that can split large size NSF files while the conversion process and allows users to save the converted files in PST at their desired location. All lotus notes versions are supported and the utility does not alter anything including email properties and header To, Bcc, Cc, From and Date. It can migrate your NSF files into numerous formats such as PST, MSG, EML, EMLX, HTML, etc. Users can also use its free demo version without any assistance.
visit here for more info: Convert Lotus Notes to Outlook
