ethanjakson
If you are having corrupted or damaged Outlook PST files and are facing issues with it, no need to worry. You can easily repair and fix corruptions in PST file using Outlook PST Repair Tool. Some of the prominent features of this software are:
- Repairs entire mailbox contents such as emails, contacts, calendars, events, journals, etc.
- No limitations for file size.
- Provides option to save resultant files into various other file formats such as MBOX, EML, MSG, and DBX.
- Supports files with encryption.
- Compatible with all the versions of Outlook and Windows.
