Ahana Singh
If Outlook keeps asking for password, it can be frustrating and interrupt your workflow. Recently, I read this article, it provides reliable methods to solve this error. Here are some steps mentioned in the write-up.
- Check your internet connection: Ensure that you have a stable internet connection. If your internet connection is unstable, it may cause Outlook to prompt you for your password.
- Clear cached credentials: Clearing cached credentials can sometimes help with the issue of Outlook repeatedly asking for a password. To do this, go to Control Panel > User Accounts > Credential Manager, and then delete any cached credentials associated with Outlook.
- Update Outlook: Ensure that you have the latest version of Outlook installed on your computer. An outdated version of Outlook may have bugs that can cause it to prompt for a password repeatedly.
- Update your operating system: Make sure your operating system is up to date with the latest security patches and updates. Outdated operating systems can also cause issues with Outlook.
- Check your email account settings: Verify that your email account settings are correct. Incorrect email account settings can cause Outlook to repeatedly prompt for your password.
