Restoration.
Al
Here's a handy little utility I came across recently, and thought I might share it with fellow Eraser users, as they may find it of use:
Restoration is a program which will help you recover any files which were deleted (both from the harddrive and the recycle bin), but not erased. The program allows you to then recover the files, or erase them totally (the option's on the drop down menu within the program). Restoration has a Windows GUI, so there's no need to muck around with command-line tools or booting into DOS mode or the like. Also it is green to the Windows registry, so when you've finished playing around with it, you can just delete it leaving no trace behind :wink:
Restoration can be found here: http://hccweb1.bai.ne.jp/~hcj58401/
