Does the program have to be open and minimized to have scheduler work?
Or can all programs be closed for faster erasing?
Also there should be a method to PAUSE operation while working, then restart when you are idle.
Thanks
1. Yes.
2. It usually won't affect the speed of erasure unless the programs are I/O intensive
3. Thinking of doing that with v6.2, but it isn't as easy as it looks...
