Save Yahoo Contacts to vCard file using Cigati CSV to vCard Converter
To save Yahoo Contacts to vCard file format using the Cigati CSV to vCard Converter Tool, follow these steps:
  1. Export your Yahoo Contacts as a CSV file:
    • Log in to your Yahoo Mail account and navigate to the "Contacts" section.
    • Select the contacts you want to export.
    • Click on the "Actions" dropdown menu and choose "Export."
    • Select "Yahoo CSV" as the export format and save the file to your computer.
  2. Use the Cigati CSV to vCard Converter Tool:
    • Download and install the Cigati CSV to vCard Converter Tool from the official website.
    • Launch the tool and upload the Yahoo CSV file you previously saved.
    • Configure the conversion settings as needed, such as choosing the vCard version (2.1, 3.0, or 4.0).
    • Click on the "Convert" button to start the conversion process.
    • Once the conversion is complete, save the vCard file to your desired location.
The Cigati CSV to vCard Conversion Tool has a number of benefits. In order to save time and effort, it supports bulk conversion and guarantees a speedy and precise conversion process. The utility ensures compatibility across a range of platforms and devices by preserving data integrity and supporting different vCard versions. This automated system streamlines the entire procedure and offers a dependable and effective method for managing your contact information.
Do you want to convert your contacts from CSV to vCard format as quickly as possible? With the use of the CSV to VCF Converter tool, you can quickly convert your contact information from a basic spreadsheet (CSV) to the popular vCard (.vcf) format, which works with the majority of email clients, mobile devices, and address books.
The most current technology enables the conversion of CSV files to vCard format simply. For a speedy and safe conversion from CSV to vCard formats, I suggest the Softaken CSV to VCF Converter Software. Even someone with no prior technological experience can utilize the application due to its user-friendly design. In addition to Windows 11, 10, 8, 8.1, 7, Vista, and XP, it is compatible with the most recent versions of Windows. Test the features and capabilities of the application by downloading the free demo version
The quickest approach to save Yahoo contacts to a vCard (.vcf) file is to use a dependable CSV to VCF conversion application. Export your Yahoo contacts as a CSV file first. After that, use a trusted solution like CSV to VCF Converter to convert the file into vCard format.
The application is easy to use, can convert many files at once, and keeps all of your contact information, such as name, email address, phone number, and address. It's ideal for bringing contacts into Android, iPhone, Outlook, or any other platform that supports vCard.
Why choose this software?
  • Fast and accurate CSV to VCF conversion
  • Supports multiple contacts at once
  • Easy-to-use interface for all users
You can use this software trial version first to test it out for free.
To save Yahoo contacts like a vCard file, start by exporting your contacts to the Yahoo in the CSV format. Yahoo provides an built-in export option that protects the entire address book as a CSV file. When you have CSV, the next step converts it to VCF format, so you can easily import it into the iPhone, Android, Outlook or any vCard-compatible app.
Instead of using the Cigati CSV to vCard Converter, I tried the WholeClear CSV to VCF Converter, and it worked smoothly. This quickly converted the Yahoo CSV file to vCard (.VCF) file without loss of data. The tool's batch supports VCF conversion to CSV, retains contact fields correctly and requires no technical skills. This is a great option for anyone who looks at CSV to easily replace the vCard format. Highly recommend it for hassle-free contact migration.
