Searching for a unique way to export Lotus Notes to Outlook?
If you search on the google for the best and smart way to export Lotus Notes to Outlook is eSoftTools NSF to PST Converter that is the top most recommended third party utility with multiple unique functionalities. The tool provides you the option to perform batch migration in just one click and also split the large size NSF files including all the mailbox components such as emails, tasks, drafts, journals, calendars, and contacts. It has the capability to perform migration in 8+ formats. All the folder hierarchy and the data structure will remain the same even after the conversion. The utility is compatible with all the editions of the MS Outlook upto 2016.
Get more info: Export Lotus Notes to Outlook
If you are in search of an unique way to transfer the data into Outlook from lotus Notes then you can take help a blog guide which I am sharing here that will make understand how to convert your data from NSF to PST quickly and safely. This explains all details related the migration process and also provide the different option to use for the conversion.
