feedback4u2
After running wipe free space on one of my dives "SATA Hitachi 500 GB" I noticed it had quite a few permission errors - I was running Eraser from a XP SP3 and wiping a Vista Ultimate drive "dual boot setup" - It appears one must run Eraser from the running platform to produce desired results - After viewing all the errors I created a standard dir "Test Wipe" on the Vista Ultimate drive and copied several files into to from Wall watcher " a windows logging program" and proceeded to wipe the free space on the Vista Ultimate drive again - The setting were DoD ??? the three pass with two additonal passes of random hex giving total pass of five - After this completed and strangely with no errrors I ran a recovery program NT Recover it is a commercial program that takes around two hours to run on a 60 GB Vista Inatall - To my dissapointment and Serious Alarm there in the test dir Test Wipe are my two Wall Watcher files not even touched as if they were just copied - I have not tried other wipe methods maybe there are issues with some and others not but one thing is for sure It would be wise to run a few recovery programs to validate your eraser program or whatever wiping program you are using is actually producing desired results!
I felt it obligated to report to the community with such a serious error! - IMO the Hitachis 500GB has been around for several years or the model has so it is not a new hybird 6GB "Magnetic / Solid State Combo" or even a pure Solid State Drive it is old fassion single platter.
