I am currently using 5.7 (I like it better than current because of initial speed)
Anyway we have multiple users that use each computer. Is there a way I can set the default settings so that all users will have the same settings.
The only settings I am wanting to set is amount of passes = 7
and the report settings to none.
Is there a file that can be created by one user and copied to all others, or registry settings that will point all users to one setup file?
:EDIT:
I should point out, I would like this to work for all NEW users, I understand current users would all have to be possibly updated individually.
Any help is appreciated, thank you
:EDIT:
