Shell Extension Error Vista
RandomPerson
Upon Installing the most recent Windows Vista x64 Updates I began to encounter an error with Eraser v6.0.6.1376 from using the right click extension for Eraser/Erase through my recycle bin. I have also tried to uninstall Eraser, reboot, and reinstall resulting in the same error
Title: Eraser Shell Extension
An error has occurred:
The requested operation requires elevation
The following is a list of the Windows Vista x64 Updates that where installed prior to the error:
Update for Windows Vista for x64-based Systems (KB976662)
Install this update to improve Internet Explorer 8's JSON interoperability in conformance with the new ECMAScript, fifth edition standard.
Update for Windows Vista for x64-based Systems (KB979306)
Install this update to resolve issues caused by revised daylight saving time and time zone laws in several countries. This update enables your computer to automatically adjust the computer clock on the correct date in 2010.
Update for Rights Management Services Client for Windows Vista for x64-based Systems (KB979099)
Install this update to resolve issues caused by manifest expiration in AD RMS enabled applications. This update will fix any existing issues in addition to addressing any future application manifest expirations. After you install this item, you may have to restart any running AD RMS enabled applications.
Update for Windows Vista for x64-based Systems (KB975929)
Both the Meiryo UI font and the Meiryo UI Bold font are included in this update. These new fonts let an application optimally display Kana characters in the Ribbon UI component and in other parts of the user interface, especially in areas where text area is limited.
Update for Windows Vista for x64-based Systems (KB976264)
Install this update to resolve issues with non-compatible applications for Windows Vista.
Go to the Eraser shortcut in the Start Menu and go to Properties (right-clicking.) Go to Compatibility and see if Run the program as Administrator is checked. If so, uncheck it.
