Hi there,
I ran into the following situation, you might be able to shed some light on. I am running Windows XP and recently installed eraser. After a while, as I found I did not use eraser that much, I decided to uninstall to free some space. Same day I tried to run Winamp (already installed) and surprisingly it didn't start. Some time later this turned out the same for QtCreator.
After some fiddling around I came around this post: http://msdn.microsoft.com/en-us/library ... 90%29.aspx. In particular the piece on Potential run-time errors:
Reinstalling the VC redistributable did not give any results (other from a slowly growing dispair :? ). Figuring from the post a not properly uninstalled library might be causing this, I decided to reinstall eraser, and voila: winamp and creator back to life.
Now for reproducing the error: uninstalled eraser again. Same effect, no response from winamp or creator. Reinstalling, back to life. For now I leave eraser installed until I have time to dig a little bit deeper. It might be some peculiarity of my machine configuration, but nevertheless, I hope you can share some insights on this.
Best regards,
Mitzl
The last two messages are the exact messages I got.If a manifest is present in your application but a required Visual C++ library is not installed in the WinSxS folder, you may get one of the following error messages depending on the version of Windows on which you try to run your application: (1) The application failed to initialize properly (0xc0000135). (2) This application has failed to start because the application configuration is incorrect. Reinstalling application may fix this problem. (3) The system cannot execute the specified program.
Best regards,
Mitzl
