alex786
OST files are Outlook data files, which is essential for Outlook users as their complete data is stored in them. If the corruption level is minor, then the user can approach to repair OST files using the ScanPST.exe. Otherwise, this solution doesn’t work well, and there is no guarantee of complete data recovery.
If you want a perfect solution with no limitations, then you can use the Shoviv OST recovery tool. Users can run this repair utility on all Windows Operating systems. Working with this solution will be easier because of its convenient GUI. Also, to use the software, users with no technical background can use it easily.
Users can add multiple OST files simultaneously and repair them all. It recovers the complete data from the corrupted OST file while also making sure to untouched the original folder hierarchy. Other than that, users can convert the added file into HTML, EML, etc.
This solution comes with the free evaluation version but only allows the processing of the first 50 per folder.
Read More: Repair OST Files
