Greetings.
I am interested in using Eraser to Zero Out Unused Disk Space (in a rarely used old Virtual PC machine, so that I may reclaim the space).
For the old version 5 Eraser product the instructions to use with Virtual PC were:
4. Run Eraser in the guest OS.
5. Select Edit->Preferences->Erasing
6. Select "Unused Disk Space"
7. Select "New"
8. Enter the description "Blank"
9. Select "Add"
10. Create a 3-byte pattern of zeros. On the "Custom Method Editor" window, near the bottom you'll see "Pattern" and underneath that, will be "Byte 1" (with 8 zeros), then "Byte 2" with a checkbox by it, and a greyed out "Byte 3". When you check the "Byte 2" box, the "Byte 3" will no longer be greyed out and you can then check it, thus creating a 3 byte pattern of zeros.
11. Click "Save"
12. Select "Blank" under "Unused disk space"
13. Click "Ok"
14. Select "File"->"New Task"
15. Select "Unused space on drive"
16. Select Local Hard Drives
17. Click "Ok
18. Select "Task"->"run on the previously created task"
19. When finished, close the report
20. Exit Eraser and shutdown the guest PC. Make sure the guest is not in a saved state.
I have gotten to page 14 of the manual, and found the custom settings, but don't know from my old notes/instructions above whether to be doing twenty-four Zeros as TEXT, or to try and type eight of twenty-four Zeros as a hexadecimal...the interface lacks they Byte order that the old one had.
Could somone please tell me what the right way to do this is? It is my understanding for the "space reclaimation" utility to work the area must be ZEROES, not random data.
Also, since I'm trying to reclaim unused disk space, I believe that I should NOT check the cluster tips erasing, as I have no sensitive material here, just need to reclaim the space...right?
thanks in advance for any help or suggestions.
As an aside thought for your consideration: it is wonderful that you include all the fancy multipass and random techniques, but is it not possible to include some pre-made techniques that just zero out space with one pass?
7. Select "New"
9. Select "Add"
11. Click "Save"
13. Click "Ok"
17. Click "Ok
