Is it possible to set Eraser to be available to only a single user?
If not, is it possible to install it such that only the user who is installing it will be able to use it?
And if this too can't be done, which Eraser entries in the Registry should be moved from HKEY_LOCAL_MACHINE to HKEY_CURRENT_USER? Or what other registry hacks are needed to achieve this goal?
BTW, this is necessary because in some cases Windows forces giving admin rights to ordinary users (not administrators.) They can easily/simply make a mistake and select Erase from the context-sensitive menu, especially because Erase is high on the menu and Delete is very low, with obvious bad consequences.
Thanks,
Uri
Thanks,
Uri
