Smart EDB to PST Converter Software
SysOZ EDB to PST Converter application has a smart preview facility which shows the recovered mailbox preview before the actual conversion process then import into new desirable file format that is PST file format. With the help of this Exchange EDB to PST program you can preserve your mate properties like To, Cc, Bcc, From, Date, Object and Time for future use. Using this tool you can convert encrypted and password protected file in a safe manner. This Exchange Recovery utility provide lots of saving formats like PST, EML, HTML, MSG for containing resultant file as well as it support Office 365 and Live Exchange Server which is a cloud based application.
Read More: Exchange EDB to PST Converter
johnsheno
You may use this professional EDB to PST conversion tool, which is the most convenient solution for converting Exchange EDB data to Outlook PST both online and offline. They may also easily move data from EDB mailboxes to Office 365 mailboxes. For PST files, the utility supports UNICODE formats. It has a preview feature that allows you to convert files manually. To have a better understanding of a tool.
