Sorry, we have trouble starting Outlook
If you encounter the error message "Sorry, we have trouble starting Outlook," it often indicates corruption in Outlook data files (PST), incompatible add-ins, or profile issues. To resolve this manually, you can try starting Outlook in Safe Mode by pressing **Windows + R**, typing **outlook.exe /safe**, and hitting Enter. If Outlook starts successfully, disable problematic add-ins via **File > Options > Add-ins**. Another manual fix involves creating a new Outlook profile through the **Control Panel > Mail > Show Profiles**, then setting the new profile as default. But this process is often slow, limited in its capability, and may fail to recover heavily damaged files.
This is where using a professional solution like the Cigati Outlook PST Repair Tool becomes advantageous. This utility simplifies the recovery process by scanning and repairing corrupt PST files efficiently. It supports recovering all mailbox items, including emails, contacts, calendars, and attachments, and allows saving the recovered data in various formats. With its user-friendly interface and high success rate, the Cigati tool makes it easier for both technical and non-technical users to restore access to their Outlook data without the complexities of manual troubleshooting.
