Split large size OST files with OST to PST Converter
The reliable and appropriate solution to convert large size OST files to PST is eSoftTools OST to PST Converter Software that speedily export any size of OST file to PST and split them while the conversion process. This toolkit safely repair encrypted OST files without altering the internal data of the OST file and also recover the erased OST files data. The software converts selected OST files including it's mailbox stuff like emails, tasks, drafts, journals, calendars, and contacts. It is the powerful utility that displays the preview of selected OST files and gives you the option to search for the specific OST files with the help of date range filter. Installation of MS Outlook is not required for the conversion. You can download it for free from the official website of eSoftTools and migrate 25 items per folder.
Visit here for more info:
If you need to move OST to Outlook PST so there are two prescribed choices to carry out this responsibility, by manual routine technique and other one is automated arrangement. While utilizing the manual OST to PST migration technique, there is in every case high possibility of error and takes a lot of valuable time. With the help of automated software you can undoubtedly export normous or various file of OST much fastly and securely.
ruchika
I would like to suggest you, try IGnissta OST Converter software Utility Program. This software is best and provide 100% Safe and secure results and it will take less time while ost to pst conversion. This software also support to convert multiple file format like: OST to PST, OST to Office 365, OST to MBOX, OST to EML, OST to MSG & OST to Vcard files.
# You can also Split Large OST file into Small Size PST file if Required
# You can Apply date Filter if you want to convert only few days, few month or few year
# Very Easy and Simple GUI which can easily understand for every one
Must Download & Install for Evaluation of Software Function OST to PST Converter & Convert OST to PST File
Easy & Simple Steps:
Browse OST File -----------------> Preview Mails Item ----------------------> Export to PST
You can easily split large size of OST file using vMail OST to PST Converter. This software restores all emails, contacts, calendars, tasks, notes, journals, etc from the OST file and export to PST file. Further, you can choose to split the PST file into multiple small sizes PST file. This software gives you the option to choose the size of each PST files for splitting.
Learn More- split large size ost file
Download OST to PST Converter
