Split Multiple PST Files?
If you are seeking the best method to Split multiple PST files into Similar PST's by Size, Date, Year and Folders, then you can try KDETools PST Splitter Tool. The Combine PST Tool comes with all the features that must be needed during this combined multiple PST files into Small Parts.
  • Split large PST files into Small Parts
  • Combine multiple PST files
  • Split heavy PST contacts, calendar into Similar PST's
  • Split large PST folders into Small PST by Size, Folders
Download Free Version allow to Split Multiple PST files into Similar PST's: https://www.kdetools.com/pst-splitter/
Using the Microsoft Outlook email client users may face many hurdles. Some of them can be big-sized PST files. If you are searching for a solution to split the PST file then you must go through this software. A user may split their PST files because of the following reasons.
• An oversized Outlook PST file can slow down your system, crash your Outlook application, and corrupt your Outlook data files.
• Users refused to save data items to their PST file folder when the PST file was out of disk space or had limited disk space.
• The outlook was unable to save the data in the PST file when the Outlook data file reached its maximum size.
Using the automated solution is an advanced solution Split PST Tool for a user to split their Outlook PST file. A tool is a simple tool that helps in the easy splitting of the PST files.
Read more :- Split PST Tool
