Paul Huntington
Split all the Oversized PST files by using the best and most professional tool which is non-other PST split . This tool is an all in one tool that not only split your PST files into multiple PST Files but it also maintains complete PST file data during the process. The software also comes with a free demo version.The PST Split solution is suitable for all types of users. Whether you are looking for individual or commercial support, the tool will meet your requirements. Supported Versions- MS Outlook 2003, MS Outlook 2007, MS Outlook 2010, MS Outlook 2013, MS Outlook 2016, MS Outlook 2019.
Download this Split PST app to your app
Read more :- Split Outlook application
- Install the app
- Select the file you want to access
- Preview the files
- Select the location to save that file
- Finally, click the “process” button.
