Split Outlook PST
A bunch of users working with outlook PST files around the globe split their files. And since Outlook offers limited space for a PST file, splitting of a PST file becomes very important for a PST file to work most effectively. For instance, older Outlook versions such as Outlook 2003 and 2007 offered up to 20 GB file space. However, for the newer version, it's up to 50 GB. A lot of software is developed worldwide to carry out the process of splitting a PST file flexibly. One of the most renowned and recommended software is Shoviv PST Splitter Software.
You can check out more features of the software here: PST Splitter Tool to Split PST File Shoviv Software
kineh96808
You can use our highly professional Split Outlook PST Software to split large sized PST Files of Outlook into Smaller and Manageable PST Files. This tool provides multiple options to split PST files without any data loss. The utility tool can easily divide PST files with all the databases like emails, contacts, tasks, calendars, and other files. Visit here for more info: Split Outlook PST | Divide Large PST Files - Free Download
tomhayden
Here everybody recommends a professional app for GainTools Split PST Software. If you’re talking about perfect answer, then this software is completely trustworthy. With the help of this application, you can safely divide your whole data from the Outlook PST file in a very short period of time.
ruchika
PST Files are bit a complicated subject because it contains emails, contacts, calendar and many more. There are different extensions for all PST components. Thus, in conversion or any kind of data practice in the PST folders can cause data corruption. So if you want Split Large PST files without corrupting it, then I will recommend you to for some automatic tools.
Here in my point, Ignissta PST Splitter is the reliable and best tool to Split Large PST File. Now with one software you can merge PST files as well as split PST files easily. This tool comes wth
  • 100% secure and complete solution
  • Life-time customer support
  • Demo version available
  • Several advance version including split and merge PST as per date, time (user choice).
    • Split large PST file into Outlook 2019, 2016, 2013, 2010, 2007
    • Split PST files without install Outlook
  • Many more ---------->
Split and merge PST files with Ignissta PST Splitter & Merger Download Software with This Link https://www.ignissta.com/pst-splitter-merger/
Easy and Simple way for Splitting PST File
1. Browse PST File -----------------> 2. Select Split Option -------------->
3. Click to Splitting
peterbay1908
The most-recommended software by most of the MVPs of Microsoft, i.e., Stellar Splitter for Outlook which I use personally as well. So this software has the major advantage where you can directly split any size data file easily with its interactive user interface and it Splits PST files by Size, Date, Email ID, and Folders. Also Preserves the structure of original PST files after splitting and supports MS Outlook 2019, 2016, 2013, 2010, 2007 & 2003.
You need to follow the below-mentioned steps to split a single PST file:
• Start 'Stellar PST Splitter'
• Click the 'Split Single File' tab
• Click 'Select PST File' to browse the file directly from a known location or click 'Find PST File' to search for it in various drives
• Click 'Change Destination' to specify the location for saving the split file
• Click 'Split PST File' and select the criteria ('By Date', 'By Size', 'By Mail ID', or 'Select & Split') to split
• Choose a location for saving the software log report. After all this, the split PST file will be saved at the specified location.
