Split PST Software application
Split PST Software application available in the market and is capable of not only dividing the contents of your mailbox but also helps split PST files Outlook 2007, 2010, etc. to render organized data after break up. The program helps users in fractionating a huge or bulky-sized PST mailbox under four different options offered by the tool. It helps users to get a convenient procedure of fragmentation whereas the backend interface has been stuffed with the most tech-centric facilities that take care of the accuracy and preciseness of the PST file processing. It splits PST without losing quality. Available Versions- Individual, Commercial.
Read more :- Split PST Software application
The Split PST tool is an excellent program that allows users to quickly divide PST files. The tool offers high levels of accuracy. This innovative approach also ensures file integrity. Furthermore, the app offers an easy platform for all users. Split PST tool is an advanced professional PST splitter software with a powerful algorithm that can simply and effectively divide a large PST file into small PST files with 100% data accuracy. Split PST File Tool supports all versions of MS Outlook and can divide PST files created with MS Outlook 2000, 2002, 2003, 2007, and 2010.
Visit here: https://www.betavare.com/split-pst/
A smart solution is to split the PST file into smaller parts using the ToolsBaer Outlook PST Split Tool. Using this tool, you can easily break the PST file by size, folder, and year and create multiple PST files with one big PST file. By using this tool to divide the PST file, you do not need to install Outlook. The utility provides the desired partition value. The commercial channel can be installed and configured on numerous systems, while the private version can be installed on two different systems. To avoid renouncing its shape, the PST data. Available versions: personal and commercial. No technical steps are needed to break the PST file. It is a small tool that users can install on their system without installing MS Outlook. This software is completely virus-free.
