Starting minimized
Links
Hello everyone,
I've been looking for some way to start the Eraser window minimized, to no avail. Even creating a shortcut and telling it to start minimized doesn't work.
There are no posts here or search results anywhere for this issue (for the new versions at least), and there is nothing in the manual. There are also no commands mentioned for starting the window minimized (or otherwise) by running 'Eraser.exe help'.
Specifically, I want it to run on login with a scheduled task to skip UAC, and I can do so either by scheduling itself or with a startup shortcut, but having it open the window in the middle of the desktop is kind of annoying.
I'm running Windows 8.1 and Eraser 6.2.0.2970.
