Step-by-Step Guide to Splitting PST Files Easily
EmmaClark
The Softaken Split PST Tool is a reliable software designed to split large PST files into smaller, more manageable parts. Users who run across the "PST file too large" problem in Microsoft Outlook will particularly find this utility helpful. This utility lets you separate PST files according to size, date, or folder so that the split files stay orderly and easily accessible. Simple interface that lets both new and experienced users divide files without data loss. The application is also totally compatible with all Outlook versions and operates with both ANSI and Unicode. It offers a free trial version to test the application before purchasing.
Splitting large PST files is simple with the Weeom PST Splitter Tool. Follow these steps:
  1. Download & Install – Get the tool from the official website and install it on your Windows PC.
  2. Open the Tool – Launch the software and click "Add PST File" to load your Outlook PST file.
  3. Choose Split Mode – Select between splitting by size, date, or folders as needed.
  4. Set Output Location – Browse and select a destination folder for the split files.
  5. Start Splitting – Click "Split" to begin the process.
The tool efficiently splits PST files without data loss, ensuring easy management.
For Splitting PST Files Easily use the GainTools Split PST Tool, which has simple and quick features to divide large PST file into multiple PST files. It saves and preserves the original database files while splitting PST.
Few steps to easily split Outlook PST file:
  • Download the GainTools Split PST Tool on your machine.
  • Click "Browse" to select the PST file you want split.
  • select your desired split point for the PST file. Based on Size, Date, and Folder.
  • choose the destination folder to save divided PST files.
  • Starting the process, hit the "Split" button. The utility will split the PST file using your chosen criteria.
If you want an easy solution to split PST files use the DataVare Outlook PST Split Expert Tool. The software is designed to split large Outlook PST files into smaller, more manageable parts. It helps improve performance and makes it easier to manage emails by breaking down oversized PST files based on size, date, or folder. It divides all PST items including emails, attachments, contacts, calendars, notes, tasks, events, etc. The utility also saves the original database file integrity. It is compatible with Windows OS and MS Outlook all editions. Users can explore the free demo version to test the application.
Try the expert solution for splitting PST files; several PST splitter software programs are available in the online market, but the MacSonik PST Splitter is the best one. That efficiently divides huge PST files into smaller ones. It is a robust and trustworthy tool for splitting PST files without causing data loss or damage. PST files can be divided by size, range, sender email, etc. The software also includes a preview option, which allows users to see the data before separating it. This ensures that users can partition PST files in a way that is appropriate for their needs. The software is suitable for all versions of Mac operating systems, such as the most recent macOS 14 (Sonoma), macOS 13 (Ventura), and macOS 12 (Monterey).
