mckevstah New Member Dec 10, 2013 #1 So i want to delete all previously deleted files, but not touch any of my installed programs or files that are not deleted. Mine is stuck at 0% and the "Status" thing hasn't moved an inch in the past hour. This normal?
R RXLA26 New Member Dec 14, 2013 #2 mckevstah said: So i want to delete all previously deleted files, but not touch any of my installed programs or files that are not deleted. Mine is stuck at 0% and the "Status" thing hasn't moved an inch in the past hour. This normal? Click to expand... How long did you end up stuck at 0%? Did you ever find a solution? I have had the same experience and am wondering if you found an answer. Thanks.
