Superb ost to pst converter software
Superb ost to pst converter by eSoftTools is the best application and easiest way for OST Conversion. Using it, users can convert single or multiple OST Mailbox files into PST at the same attempt without any problem.
This
OST to PST Converter software has a preview ability that shows the preview of all OST Mailbox's data before finishing the conversion task of the OST data file to PST. It also able to exports data into EML, EMLX, MBOX, MSG, HTML, vCard, and office365 formats. Software supports all versions of Outlook, and Windows OS. Free download the demo of this tool and also convert the first 50 data items per folder.
Get the free trial software -
https://www.esofttools.com/free-ost-to-pst.html
camilia
All Users can quickly import single as well as multiple files into many formats like PST, Zimbra, Gmail, EML, EMLX, vCal, vCard, HTML, MBOX, Office 365, Live Exchange Server and etc. here is no requirement for some practical ability to routine this third-party utility. Through its utility converter, all Outlook users can also export your lost and permanently delete data in a couple of clicks.
  • For PST, you can also split resultant file according to size.
  • Message Filtering: This option allows you to export OST items as per given date range.
  • Folder Selection: You can also select/ deselect OST folders from the left pane of the software. This option helps you to export only required folder(s).
More info- OST Converter - Convert OST to 10+ File Types
Using OST to PST Converter Software is very easy or operate without any problem. you can use this software for converting OST files into Outlook PST file format. This tool supports all the versions of MS Outlook and Windows and allows users to import OST to PST, EML, MBOX, EMLX, HTML, and MSG. It facilitates users to convert selective single and multiple OST Folders and provide a preview of OST File data. The free trial version which transfers the first few items from each folder. It smoothly supports all versions of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019 and does not require the installation of MS Outlook for the conversion process.
eSoftTools OST to PST Converter is a professional solution for those users who are looking for repairing their corrupted OST database. Through the support of this software, you can convert just a few minutes then I suggest you download this software and trial to free demo version. The OST to PST Converter software carefully transfers all OST email folders to PST format, including attachments, appointments, notes, junk mails, contacts, calendars, tasks, etc. This Software Supports MS Office 2003, 2007, 2010, 2013, 2016 and 2019.
More details, visit:-
Superb OST to PST converter software that is fueled by SysInspire which is help to convert OST files. User can relocate their OST data into different configurations like-PST, HTML, ICS, MBOX, CSV, EML, EMLX, vCard, and Office 365. With best of OST Converter software highlight, that can split the PST files into small PST file with no data loss. This is most straightforward and quickest tool for conversion and recover OST to PST data. The whole supporting forms of Outlook OST and Windows form up to 10. Hers User can move 25 OST items from each organizer with the assistance of free demo rendition.
By click this link you can get free trial version software -
