SYSessential Excel to vCard Converter Software
johnsheno
SYSessential Excel to vCard Converter Software is the best software for quickly converting Excel files to vCard files. This tool provides a free demo version that allows you to convert 5 contacts from Excel to Vcard(.vcf) in under a second without losing any details, and it offers two conversion options: separate vcard files and single vcard files. It also allows you to import contacts into Microsoft Outlook, Android phones, and WhatsApp.
Export Excel contacts to vCard format
1.
Move contacts folder by searching contacts on Windows search bar.
2. Click on the Export button and select the file format as vCards
3. Click on the Export button
4. Browse the destination location to save vCard file
5. Click OK to export Excel to VCF without any software
chaselee
This application is useful to GainTools Address Book Manager Windows without losing and altering data files. This software provides the complete and safe migration from Excel data to vCard format. The utility successfully supports all CSV and Excel files. It also supports all Windows OS versions. Go ahead and take a trial to transfer contacts from an Excel file to a VCF file.
Visit here:- https://www.gaintools.com/address-book-manager/
