SYSessential Excel to VCF Converter
johnsheno
The main reason for converting XLS contacts to vCard format is that vCard files allow for easy sharing of contacts to any computer, while contacts in Excel files are restricted. Users can access Excel contacts on their Android phone, iPhone, Thunderbird, Outlook, Gmail, Whatsapp, and other devices after exporting XLS contacts to VCF format.
Steps to export XLSX contacts to vCard format –
1. Run the XSL to VCF Converter Tool after installing it.
2. Select an Excel file using the Browse button.
3. This will show all of the contacts in the Excel file. You can map Excel columns to vCard fields in this section. Press the Export button now.
4. Select the Browse button and enter the place where you want to save the VCF file. You can choose to “Export all Excel contacts into a single vCard file” from this menu.
5. Click the Export vCard Now button to convert all of the contacts in the Excel file to vCard format.
Read More: Excel to VCF Converter
Address Book Converter Software is programmed to smoothly convert and manage address book. Users can easily export, import, split and merge VCF files with this application. The program needs no external program to convert address book. Without any trouble, users can import VCF files to PST, NSF, MSG, and CSV file format. Also, users can export VCF file from PST, OST, MSG, NSF, Excel, CSV, etc
Some tools are available in the market, you can search through google or i will recommend Softaken Excel to Vcard Converter tool, this software will help you to convert emails from Excel to Vcard file format.
Excel to vCard Converter is the comprehensive and full-featured utility to convert Excel Spreadsheet XLSX / XLS to vCard format. It allows users to convert different Excel files XLS, XLSM, XLSB, and XLSX to vCard. The software is competent enough to create a single file for all contacts and saves it as blank contact without any data loss. Moreover, you can
MacSonik Excel to vCard Converter for Mac is a trusted professional solution to convert Excel files into vCard. It maintains the original data integrity and high data security throughout the conversion process. This Excel to vCard Converter Tool supports multiple Excel file formats like XLSX, XLS, XLSM, XLT, XLTM, XLTX, and XLSB. There is no need for MS Office installation and users can efficiently export all the sheets from Excel files to vCard, TEXT, and CSV format.
Now, easily convert a contact file to a vCard file format with WholeClear Excel to vCard Converter. It allows users to convert large contact files to vCard format, after that, users can import it to multiple devices like iPhone, Android, Outlook, Gmail and more. Additionally, it has a simple and user-friendly anyone without technical knowledge can run easily. This tool supports all Windows versions like 11, 10, 8.1, 8, 7, XP, and Vista. It is a totally offline tool not require any kind of internet while converting.
