SysOZ NSF to PST Converter - IBM Lotus Note
SysOZ NSF to PST Converter is developed by the best of the best IT professionals this converter is based on a highly advanced algorithm. NSF Converter can split the large-sized PST file into small bits as per your needs. Try the free demo version of the converter to convert 30 emails each mailbox items to PST file free. The software does not create any difficulty in front of you during and after conversion. The novice and professional both use it without any technical skills and knowledge. With the help of this tool, you can convert NSF data into various formats like PST, EMLX, vCal, vCard, MBOX, EML, and MSG, etc. Lotus Note Converter Software Supports Lotus Notes 10.1, 9.0.1, 9.0, 8.5, 8.0.2, 7.0, and 6.0 versions. It supports all the versions of MS Outlook up to 2019. The users can migrate the data of NSF file into Outlook PST and Office365 & Live Exchange Server that is an additional feature of this application.
Free Download Software: https://www.sysoz.com/dl/nsf-to-pst-demo.exe
By taking the help of Bitdataconversion NSF to PST Converter Tool. Users can migrate single as well as multiple Lotus Notes NSF data files into PST Outlook and other file formats such as EML, and MSG without losing any data. With the help of this tool, users split their large files into several small files as per their requirements. The size of the NSF file is not mattered for the conversion task. It supports OS Windows version Win XP, Win Vista, Win7, Win 8, Win 8.1, and Win 10 (32bit & 64bit). Install its free trial version and convert the first 50 data items/folder and It also gives 1 month money-back guarantee and free technical support.
For more details, visit - NSF to PST
As per the suggestions and experience of the majority of Lotus Notes users, the most convenient technique to convert NSF to PST file type is by using a trustworthy tool. One such type of application is developed by eSoftTools and is known as NSF to PST Converter Tool. This software is developed in such a manner that even a person who does not have technical knowledge about Lotus Notes can operate it very efficiently. This software has the ability to restore deleted email with all attributes like- bcc, cc, subject, hyperlinks, to, from, attachments, embedded images, and many others. Even a huge PST file can be split into small packets of new PST files. A free demo version is also offered to all users with support to all editions of Lotus Notes and Outlook.
Get More Info:- Convert NSF to PST
If in case, you are searching for a way that can easily help the user in NSF to PST conversion then go for eSoftTools NSF Converter Software. This tool is efficient enough to work well with all the variants of NSF file evening in the damaged situation. This tool can act like a Lotus Notes file viewer and thus provides an inside preview of the complete database without any doubt. The user does not need to install Outlook for migration and also has the facility to export the entire or some part of the mailbox. All components of the mailbox can be exported including e-mails, notes, contacts, calendars, and many others. Data can be filtered on the basis of date through date filters. The consistency of the data is retained as it is in the original mailbox. A free demo is also provided so that everyone can check the efficiency of the tool for free.
Read more - Free NSF to PST file Converter
Are you finding a convenient way of exporting NSF files to PST format? You can convert NSF files to PST with the help of Softaken NSF to PST Converter. You can quickly move your NSF file to PST formats without any hassles. You can swiftly go with the utility without any hesitation. Therefore you can flawlessly save Lotus Notes NSF emails to PST file format in just a few days. You can download its demo edition for free to evaluate its functioning.
