Thunderbird to PST Converter
As a solution, I recommend using the eSoftTools Thunderbird to PST Converter Tool. This application will guide you through the process of converting Thunderbird files to PST format without losing any data. This is a reliable tool. You can download a free demo version to learn more about the software's features and how to use it. With ease, convert any large Thunderbird file to PST format.
For more info- Thunderbird to Outlook Converter
Danish
You can also go with the Manual Solution to Convert Thunderbird to PST files, you have to follow these steps:
Transfer Thunderbird messages to EML Manually
  1. Run the Mozilla Thunderbird application and select the mailbox folder in which the emails to be exported reside
  2. Now select the required messages in this mailbox folder. Use Ctrl+A for the selection of all the email messages
  3. Next, right-click on any of the selected emails and hit the Save As an option
  4. Create and select a folder on the local system to save the Thunderbird emails as EML files.
After that, Move the Converted Email files into Outlook for Free.
