alex786
Lotus Notes used to dominate the email client niche, but as time changed, the user started shifting to another emailing platform that works on the cloud. One of them is Office 365. If you are also one of them looking to migrate Lotus Notes to Office 365, you need to adopt a better approach. Some users try the manual method, but few of them can get success in it.
Another option, which is much more reliable and safer, is the professional migration tool. If you are on the same page to migrate email clients without taking any risk and wish to achieve success, you can adopt a third-party migration tool. You can employ Shoviv Lotus Notes to Office 365 migration tool that makes migration easier due to its smooth user interface. It gives you control over the migration process, which means you can add multiple Lotus Notes mailboxes of any size and filter out any selected item from the migration.
It also provides folder mapping functionality that makes it possible to migrate one particular item from one to another folder. You can also try the tool's free trial version to examine the rest of its features.
Read More: www.shoviv.com/blog/migrate-lotus-notes-to-office-365-step-by-step-guide/
