Ultimate Windows PowerShell Solution for OST to PST conversion
One way of using Windows PowerShell to convert OST files to PST format is possible but it has some drawbacks.
Steps using PowerShell:
  1. Perform PowerShell from a Windows desktop with an administrator.
  2. Set the execution policy with: As a command line, it is Set-ExecutionPolicy -ExecutionPolicy Unrestricted.
  3. Use the ls command to check which folder you are currently at then, use the cd command to get to the OST file folder.
  4. Drive the OST file data into the CSV format by creating a PowerShell script.
  5. Open a new PST file in Outlook and import all values that are encapsulated in CSV.
If one is looking for more enriched employment, the WebbyAcad OST to PST Converter Tool is the best for converting files with ease and efficiency without disturbing the size of the file or data.
