Jesse Kornblum has just release SSDeep which is a fuzzy hashing tool. unlike normal hacking tools (such as md5sum, md5deep) ssdeep allows an investigator to compare portions of a file with a known good file hash.
With the way ultra quick erase works, just deleting the first and last 2k of a file, it still leaves enough of the file that a fuzzy hash will work
(Note: comparing a fuzzy hash requires access to the original file, so if you are dealing with files only you have, the threat is reduced, however if you are eraseing, porn, warez etc this is very much an issue)
For more information on it, take a listen to an interview with Jesse on Cyberspeak
