Unused partition erase failure
nobelrichy
Hi,
At the end of erasing process for unused partition, I met the following messages:
- Could not make the temporary file
- Error: Failed to erase file names from drive H:\, don't know why exactly.
I tested it on Vista Enterprise edition.
Regards,
Nobelrichy
Hi Nobelrichy
I am sorry you are having trouble with Eraser.
Have you disabled UAC ? Instructions here.
Do you have the necessary permissions for that drive ?
Could the drive be damaged ?
How is the drive formatted ?
Is the drive attached physically to your computer or is it over a network ?
> Yes, I had disabled it after reading that instruction you mentioned before.
> Yes, I have it. Erasing process was started normally.
> That message appeared around the end of ersaing.
> It's very normal status. I tried scanning sectors and found it's fine.
> It's formated as NTFS.
> It's attached my dell PC inside.
Hi Nobelrichy
Thank you for coming back.
Is the drive encrypted or compressed ?
Could anything have blocked access to it part way through the process ? Back up software, anti virus etc ?
I know you said the drive is NTFS but is the partition you are erasing formatted ?
If there is none of your data on the partition could you format it and erase the free space again to test please ?
I assume you have the latest version of Eraser installed.
Thanks.
Hi,
Please check the below.
> No, it isn't compresssed.
> No, not at all.
> Yes, it is formatted with NTFS.
> OK, let me try it.
Thanks a lot,
Nobelrichy
Hi,
After formating the partition it was completed successfully.
But I tried it again on C drivce and get the similiar message as the following:
Information:
Statistics:
Erased area = 2852 MB
Cluster tips = 0 bytes
Data written = 2852 MB
Write time = 130.89 s
Write speed = 22313 kB/s
Failures:
Failed: C:\~ERAFSWD.TMP\AVF80007.YOO
But I couldn't find that folder and file.
And I tried to recover it using the commercial recovery program, but there's nothing at all.
Regards,
Nobelrichy
