unused space erase possible problem
Status
Not open for further replies.
delapisina
Hello,
I downloaded version 5.84 last night and started running an unused space erase. I've never used Eraser before. I'm quite concerned because it's been 9 hours now and the program appears to still be running. I've tried to see if there is anyway to check the progress since I read in the forums that some people indicated that they got an error message when an X% of the process had been completed. :? I can't seem to find any indication of progress anywhere, neither a progrees bar nor a percentage amount. I also read in the forums that it is not recommended to quit the process. What shoud I do? I need my computer to get back to work! :(
In the Statistics tab of the task properties I get the following report:
Task Report:
Processed = 1 times
Successful = 0 times
Terminated = 0 times
Possible failure = 1 times
Statistics (average):
Erased area = 0 kB
Data written = 0 kB
Write time = 0.00 s
And this is what's in the log:
9/7/2007 12:17:27 AM: Scheduler (5.84) starting.
9/7/2007 12:34:31 AM: Scheduler (5.84) starting.
9/7/2007 12:35:09 AM: Scheduler (5.84) starting.
9/7/2007 12:35:53 AM: Scheduler quitting.
9/7/2007 12:36:09 AM: Scheduler (5.84) starting.
9/7/2007 12:37:39 AM: Scheduler quitting.
9/7/2007 12:37:55 AM: Scheduler (5.84) starting.
9/7/2007 12:49:27 AM: Scheduler quitting.
9/7/2007 1:42:53 AM: Scheduler (5.84) starting.
9/7/2007 1:45:21 AM: New task created (C:\).
9/7/2007 1:46:41 AM: Removed a task (C:\).
9/7/2007 1:47:59 AM: New task created (C:\).
9/7/2007 1:49:20 AM: Running task (C:\).
I look forward to you soonest reply. Thanks, -Delapisina
Status
