I am running Eraser 6.0.7.1893 on XP Home SP3 on a laptop.
I ran task erasing unused disk space including cluster tips for about 10.5 hours & about 90-95% complete but had to abort due to time constraints. The built in stop did not appear to work so I had to abort the program itself. My problem is that it left behind a hugh folder (about 330 MB according to my defrag software) and that appears to be overwhelming my Explore program so I am having trouble deleting that file because it never finishes loading the file list within that folder for Explore to read and it keeps my hard drive running & bogging down my entire computer for other programs.
Any simple work around idea's from anybody to remove that huge folder. I tried directly from DOS prompt but the filename appears to be a problem with that method. Tried renaming it through Explore but it tell me it is in use by another program & cannot rename it. Thanks in advance.
