Vartika NSF to PST Converter Tool
If you are unable to fix Lotus Notes NSF file corruption issues with the help of manual methods. Don't worry about it, you can solve your all the (.nsf file) corruption issues with the use of Vartika NSF to PST Converter Tool. It is professional converter tools that can assist you to recover unreadable NSF file data and transfer them into new or existing readable Outlook PST file, MSG, HTML, vCal, EML, vCard, MBOX, CSV, EMLx, file formats and also with Live Exchange Server, Office365, etc. It also repairs the password-protected NSF files. Download the freeware Trail Pack of this utility to check your NSF file data has been recovered or not. In the Trail Pack, users can safely transform the first 30 emails per folder is free of cost, and if the user is not satisfied with this utility, cash-back assurance available within 30 days of software purchase. All the Versions of OS Windows (32bit & 64bit) and 2007, 2016, 2010, 2019, 2013 & older versions of MS-Outlook are workable in this tool. The software is workable with all the editions of Lotus Notes such as:- 9.0, 9.0.1, 8.5, 6.0, 8.0.2, 7.0, 10.1, and 6.5 editions.
Read more : Vartika Migrate NSF to PST Converter
Shoviv Lotus Notes to Outlook Converter Tool is the best application and easiest way for NSF to PST Conversion. Using it, Users convert single as well as multiple Lotus Notes NSF data files into Outlook PST at the same attempt. This application has a preview facility that shows the preview of all mailbox's data before finishing the conversion task of the NSF data file to PST. It also able to exports Lotus Notes data into EML and MSG formats without any intrusion and supports all versions of Lotus Notes, Domino Server, Outlook, and Windows OS. The tool gives you the safety and guarantees to convert data without any data loss. Download its demo version and users can test the tool and also convert the first 50 data items per folder. It also provides 24*7 technical support.
More details, visit:- NSF to PST Conversion
Try Softaken Lotus Notes to Outlook Converter to convert Lotus Notes files to Outlook with all metadata and properties. The tool is specialized in moving Lotus Notes data with attachments to Outlook. It supports Lotus Notes file migration to all the Outlook editions, such as 2019, 2016, 2013, 2010, 2007, and 2003. Download the demo edition of NSF to PST Converter to grab more information and move up to 10 NSF files to PST for free.
