Vartika OST to PST Converter
Get the amazing utility Vartika Outlook OST Recovery or Repair Software to recover & export damaged mailbox data of OST file including Emails, contact, calendar, tasks, drafts, notes, journals, images, deleted items, attachment, etc into workable file formats such as Outlook PST file, NSF, vCal, MSG, PDF, EML, vCard, HTML, EML, NSF file & cloud applications Office 365, Live Exchange Server. It can workable with MS-Outlook editions 2002, 2007, 2010, 2003, 2013, 2016, 2019 and all the editions of OS Windows including Windows 95, 98, 10, 8, 8.1, 7, Win XP, Win ME, Win NT, Win Vista (32bit & 64bit). Try its freeware trial version, which allows you to exchange 30 email items from each folder without wasting more time. The software provides a money-back assurance to the user under in 30 days of toolkit purchase. This software has multiple advanced options, in which you can recovers all the permanently/deleted mailbox items of Offline OST file and also it helps you to convert your large size OST file data into several small Outlook PST file as per your demands.
Read more : Vartika OST to PST Converter - Convert OST file into PST
The OST to PST Converter offers the safest and most prominent way to import all emails, mailbox items of OST data into the new output PST data that you can save at the desired location. Through its technology & great solution you can deeply scans damaged OST files and export OST to new Outlook PST file formats with PST, Office 365, Live Exchange server, Zimbra, Gmail, EML, EMLX, vCard, ICS, MSG and etc.. The free trial version helps users get familiar with the features and the working of the software.
Show the preview of all OST emails including these items:
Messages
Embedded Images
HTML Formatting
Header's Details
Contacts
Calendar
Tasks
Notes
Journal.
  • For PST, you can also split resultant file according to size.
  • Message Filtering: This option allows you to export OST items as per given date range.
  • Folder Selection: You can also select/ deselect OST folders from the left pane of the software. This option helps you to export only required folder(s).
More info- https://gust.com/accelerators/convert-ost-to-pst-manually
There are best solutions available for converting OST file format to PST format without any data loss. The application works on all versions of MS Outlook 2000, 2002, 2003, 2008, 2010, 2013, 2016, and latest 2019. The tool provides users with the flexibility to export data from any perspective version. I would recommend you to download this OST to PST converter tool and easily move the OST file to PST format.
More info:- https://www.sametools.com/convert/ost/
If you want to convert OST files into Outlook PST, then OST to PST Converter is the best reliable tool for this task. This tool is highly recommended by experts because of its powerful success rate. This tool can convert single as well as multiple OST files at a time. It also converts files into 15+ file formats and various email clients.
I would suggest you to use the OST to PST Converter tool to convert the OST files into PST file format with 100% data accuracy. This tool is a 100% reliable and prominent solution to opt for converting the OST to PST, EML, CSV, HTML, MHTML, EMLX, MBOX, and MSG file formats. It is competent enough to repair inaccessible or corrupt Exchange Outlook OST files with ease. You can also download its free demo version to evaluate its functionality.
