BloodySword
Hello.
I don't like the new version. First of all, it looks like a "dumb user"-program... But that is not so frustrating like these things:
- I installed the "stable" version and wanted to change the default erasing command to "First/last 16k". After that I wanted to create my own ones by clicking on the plugin's settings. But Eraser disappeared suddendly without any error message. Since then I could not start Eraser anymore. It said, That there is no default erasing algo selected for the first/last 16k option. I should change it in the plugin's settings. But Eraser isn't starting...
- I installed then one of the nightly builds, but erasing didn't work at all. It said there were errors. In the log, there was "1007 is not a valid number" WTF?
- I installed an older nightly built, which worked. But it uses the sheduler, which I don't need. I whant eraser to erase the files IMMEDATELY from the explorer contextmenu.
- There is no way to choose from the algorythm which will be used for erasing for files, folders and the recycle bin. I can't see any progress and after completion, explorer is not refreshed. I have to press F5 for the files to disappear.
I'm using Windows Vista SP2 Up to date!
My suggestion: The context menu is not configuable. Make it configuable so that the user can decide which menu entries he wants and in wich objects the menu should appear. Even the position in the menu should be configuable. And there MUST be a list with all available erasing methods to choose from. So if the user has choosed one, a window with the progress should be shown. And it should be shown wich file is processed at this time, like it was in the old version 5.88.
An additional suggestion is to add a new custom method additionaly to "Random numbers": Writing the complement of the byte. First erasing with the complement of the read byte, then with zeros is a fast and good erase method for personal use. Let's say you would like to sell your old HDD to some stranger. Deleting the whole drive whith this method is safe enough and FAST.
I will use version 5.88 till these problems are not solved.
