For best NSF to PST Conversion, the better way is to try a Third-party tool and I would suggest Shoviv NSF to PST Converter tool. Because Shoviv provides better security and converts data with accurate results without any data loss. It also provides the 100% guarantee to convert accurate results for NSF to PST Conversion.
The provides the multiple Features:-
1:- Convert NSF data into Bulk at the same time into Outlook PST, EML, and MSG formats.
2:- Also Provide Mapping, Filter, and Split option
3:- Data preview option before the actual conversion
4:- Supports all versions of IBM Notes, Domino Server, Windows OS, and Outlook
5:- Free demo also available and it helps to convert the first 25 data items per folder.
