monor
The easiest way to export PST contacts into CSV format is by using a simple method through Microsoft Outlook or a professional tool.
In Outlook, you can go to File → Open & Export → Import/Export, choose Export to a file, then select Comma Separated Values (CSV). After that, pick the Contacts folder from your PST file and choose a location to save the CSV file. This method is straightforward, but it may take time if you have multiple PST files.
For a quicker and more flexible option, you can use a PST Converter Tool. You add the PST file, preview the contacts, and select CSV as the output format. It allows bulk conversion and keeps all contact details properly organised.
Using a reliable solution like BLR Tools makes the process even easier and helps you export PST contacts to CSV without any hassle or data loss.
For more details: Best Methods to Convert PST File to CSV
