What’s the easiest way to switch big ZIP archives into 7z format?
Big ZIP archives often take up more space than needed. Converting them into 7z format is a good idea because 7z usually gives better compression. The manual method would be to extract everything and then create a new 7z, but that’s slow if the file is huge. A faster option is to use a dedicated conversion tool. The Softaken Archive Converter software can switch ZIP into 7z directly without extra steps, and it also supports formats like RAR, TAR, and GZ. It works smoothly on Windows systems, even with large archives, and comes with a free demo to test first.
