What exactly does erazer do?
Chiefmole999
It's not really clear from the description what erazer does. What I want is something that will overwrite the section of the hard drive that does not contain any data, but that will not interfere with any of the data or program softward or operating system that is on the same hard drive. Is this what eraser does. It is not clear as far as I can see.
Regards Chiefmole.
Yes, that's what it does!
I suggest you read the Help files on the program itself before using it - the files give a clear explanation of what eraser does.
