What is Softaken EDB to PST Converter and how does it work?
chanwoges
Try Softaken EDB to PST Converter if you want to convert EDB to PST files quickly. It is an outstanding tool that allows you to repair and export corrupted or unavailable EDB files to the PST format.
EDB to PST Converter's salient features include:
  • Allows numerous EDB files of any size to be converted.
  • It can also fix damaged EDB files.
  • It has the ability to convert EDB files into ANSI and Unicode PST formats.
  • It provides a split option for huge resultant PST.
  • Allows Exchange mailbox objects to be previewed.
Complete or incomplete mailboxes can be imported and exported between Live Exchange, Office 365, MSG, EML, HTML, vCard, and many more programs.
You can begin by using the free trial version, which makes the EDB to PST conversion easier and helps you understand how it operates. This is due to the tool's improved functionality and ease of use, which make it simple for users to convert EDB to PST files. Exchange EDB files can be directly converted to Outlook PST files while maintaining the folder structure and all attachments and metadata. For huge and corrupted EDB files, its sophisticated algorithms ensure a speedy and correct conversion. The method is comprehensive and effortless because of how simple it is to use.
